Thanks for posting another good article, Larrin. A point or two about the heat treatment...
"Many knifemakers use 1475°F and 400°F, which would lead to about 59.5 Rc. I’m not exactly sure why they use 1475°F, perhaps it comes from copying recommended heat treatments from 1095."
Those of us who use the 1475F austenitizing temperature for 52100 aren't copying the recommended heat treatment for 1095. We are copying Kevin Cashen's recommended heat treatment for 52100, truth be told!!! Perhaps the heat treating numbers cited in the article ("This is why the recommended hardening/austenitizing temperatures of 52100 is higher than 1095, usually 1550°F rather than 1475°F") are for 52100 in the annealed (spheroidized) condition, and I am almost certain that is the case. Why we choose the 1475F+soak for 52100 is heavily dependent upon what the carbide condition was prior to hardening. If the 52100 was in the spheroidized condition (especially a heavily spheroidized condition), the 1550F austenitizing temperature would be necessary (and maybe not hot enough!). But after normalizing to break the carbide bond and free up carbon for solution (and then thermal cycling to deal with any possible enlarged aus grain issues), the 1475F, soak, quench gives maximum hardness post quench, 66-67HRC, and 400F tempers result in ~62-63HRC.
"The peak in hardness comes from an austenitizing temperature of about 1650°F". That may be the case when hardening/quenching from a heavily spheroidized condition, but when hardening/quenching from pearlite (after normalizing/cycling), the peak hardness falls in that 1475F-1500F range.
I once spoke with Kevin and asked him specifically about the industry standard recommended 1550F (after normalizing/cycling and quenching from pearlite or even martensite) for 52100. His reply was it works good for ball bearings, but not so much for a fine cutting edge for at least 3 reasons.....a lower "as quenched" hardness, higher % RA, and higher % plate martensite.
