- Mar 8, 1999
When I got some swords, they came unedged. I found one tool invaluable in putting a real edge on them.
It was a Buck sharpener, though I've seen them under different namees. A handle with two small pieces of carbide held in a V and a small half bow to guard your fingers.
The directions say to use it with light pressure for sharpening. What I've found was that it can also be used with pretty heavy pressure to hog material off. I've done a couple of unedged swords that way, and it kept hogging metal off the sides until I had a pretty good bevel on either of the blade's sides, and I got close to having an edge. Then I finished it up with a file and had a decent convex edge.
What I'm using it for now is the OPPOSITE OF THE ABOVE. I'm taking down a thin edge using it here and there, now and then. And it's working! Bit by bit the edge is getting thicker. And staying sharp!
Thought I'd pass it on in case others might want to try it.
