Did that ! Lubed with #10 Nano-oil.Lubricate with a thin oil. And if needed, disassemble and clean.
This is quite possible. Thanks, that is a great idea. I will try that.Check the axis lock rod. If it has even a small imperfection/imperfections it will cause really bed drag. Mine (a larger purple Ritter) was fixed after I sanded and polished the the axis lock rod. Before fixing it had little problem opening but really bad stiff nasty un-smooth drag when closing and no amount of Ballistol oil changed it. In my case there were times it closed smoother but still not good and then back to really bad. I tried polishing the blade contact area but nothing changed until I turned my attention to the lock bar. I found out because I put the blade in another working Ritter grip and it worked smooth as butter. That ruled out all but the lock bar which did not look too shabby but after I removed/reduced what appeared to be insignificant scratches it worked smoothly when I put the blade back in.
Often the axis lock rod turns as it rides the contact area at the bottom of the blade during opening and closing. It could be that it rotates at some point to an unblemished area that permits smooth opening and closing before rotating back to where the imperfection produces drag again. If, If that is the problem a new unblemished lock bar would make quick work of fixing the issue. That would be the most ideal way to fix that problem.
I think I've found it!
There is a "gummy" substance on washers, blade, pivot pin, cross bolt, springs.
Obviously, the Nano-oil turns to gum, slowing things down. Never happened to me before with Nano.
I use it on many other knives (this is my first Hogue).
Guess I will soak parts in alcohol, then scrub with tooth brush.
Lube with?????
May have been something odd on it from the factory. I’ve never had this happen with nano oil and I have it on my Ritter Hogue.I think I've found it!
Lube with?????
Disagree. I’ve used everything from Frog Lube to Tuf Glide, and nano oil has worked way better than most, including TG. Only thing I haven’t tried is KPL.Nano oil is overrated and overpriced. I don't feel it's better than tuf glide. Plus they use some cheap material to make the tube such that it cracked the other day when I squeezed to apply some drops to a knife.
What I've been using for the last 15 years is Hoppe's #9 and CLP. For the passed few months I've used strictly the Hoppes and it has been working amazingly. All of my knives that I've taken apart, cleaned and oiled have come out smooth as glass. I put a few drops on the tip of a Q-tip and then brush the q-tip on each side of every moving surface. Just enough to keep it lubricated but not so much that it leaks out at all and gets on your paws.I think I've found it!
Lube with?????
I agree. Being a gun and knife guy my whole life I've used a lot of different lubes and have come to realization that nothing fancy is really needed and most anything makes it nice and smooth.I like Ballistol because it's non toxic as well as a time tested and proven oil. These days they no longer use whale sperm in the recipe. WD-40 is excellent for cleaning gunk but you must wipe all traces of it clean when done or it leaves it's own gunk behind.
My understanding is the oil requirements for small mechanisms like guns and knives are minimum and any decent quality oil should work fine. Nothing special is needed.
