- Oct 14, 2018
1. Is there a good way to hand sand the bevel of a hollow ground knife? Wondering specifically about switching directions as I switch grits. Or should I be focusing on refining the scratches with the belt sander? See first photo. I’m pretty happy with the finish, but it’s not perfect. I am a little more confident with hand sanding than with using the belt sander.
2. How important is perfectly consistent TBE across the blade? The kitchen knife in the last pic was not consistent, it was probably twice as thick closer to the handle than closer to the tip. Hard to see in pics, but the first inch or so is lower than the remainder of the knife after sharpening. The hollow ground knife is not perfectly consistent either, and I don’t want the same problem with the edge being a little wonky.
Thanks for any input.
