Well, on the smaller end of your scale, 10 inches overall is not very big at all, and unless it was made from stock a half inch thick, it will be plenty light and quick without hollow grinds.  If we start talking about something around 20" long, then perhaps hollow grinds might be an option if quickness is a priority.
Keep in mind that the grinds are a lesser part of the equation when it comes to cutting.  Edge geometry is what makes the blade cut for its intended purpose, and the edge geometry can be controlled separate from the grinds.
Also, when it comes to weight and quickness, we can't always assume a lighter blade will be quicker.  If the maker knows what he's doing, he will include the proper tapers in the grinds to make the blade naturally well balanced.  He can also do tricks with the weight of the pommel to fine tune the blade for speed or whatever you want to do, but the blade must be properly built for the purpose first.  Now, to make a very generalized statement, I'd say on average, a smith who makes big flat ground or convex ground blades will probably still produce a knife that feels more lively in the hand than a stock removal hollow ground knife of similar size.  Reason: chances are the smith put in the proper tapers since it's so easy with a hammer, while stock removal makers rarely do, but rather leave lots of dead weight on the spine near the front of the knife.
I'll also say I have a flat ground Rio Grande camp knife, or spear point Bowie, that's 18" long.  That sucker is quicker than the dickens!  (very low moment of inertia)  It used to be 21" long and balanced so the natural center of percussion was near the point.  When 3" were broken off the tip, it shifted the balance point (and accompanying centers of rotation) pretty far back.  Now it completely sucks as a chopper, but that point is lightning quick for thrusts.  (again, be reminded of the compromises involved when making a blade very good at one thing)
