Hey guys,
I want to try my hand at a hollow grind, but the only grinder I have is a cheapo Craftsman 2x42. Is there an inexpensive standalone wheel setup I can try?
My funds are pretty limited right now.
Hey guys,
Here's my Stupid Cheap Massive Hollow Hawger :thumbup:
I have maybe $25.00 in it! the wheel is 4 - 24" square pieces of 1/2" hardwood plywood. glued and screwed profusely. then the center is marked and drilled. a bolt is inserted in the hole, and a 12" string is attached, and an arc is struck to mark the corners. next jig saw or band saw the corners off. Go to a junkyard and find a 5-6 lug truck axel (the short shaft off a front 4WD is REALLY NICE) then drill your wheel center to accomodate the axel diameter. get ya a couple of pillow block bearings to match the diameter of the axle shaft. drill a 1" hole 2" from edge and cut a thin slot to the hole. a taper hole will hold the paper better than a traight hole but either will work. just put a tight fit pin in to hold the paper tight. add motor and pulleys... Use a wood lathe gouge to run in to true. Hope this helps!
