- May 2, 2004
My good friend Jeff stopped by last weekend, he had two sets of mower blades for his big zero turn mower that he wanted to sharpen using my 2 X 72 belt grinder along with a bubble jig to keep the angles even.
Both sets of blades were used on his 28 hp zero turn mower and were from the same manufacturer. Putting our heads together, which does not always turn out well, we decided to sharpen one set of 3 blades on the flat platen, the other we decided to try a hollow grind on an 8 inch wheel.
As we sat around the shop having a beer we discussed what the differences might be. I thought the hollow ground blades would tend to cut with less drag as the grass came off the cutting edge. Less bludgeoning and more like slicing. The edges were kept at the same thickness and were not knife blade sharp by any means.
Jeff headed home to mow his 5 acres of grass. He mowed the first half with the chisel ground blades and the second half with the hollow ground blades. He gave me a call the next day and said there was no difference in the quality of the cut; but the big mower did not work any where near as hard to do the same job with the hollow ground blades. He used less gas using the hollow ground blades.
I couldn't decide exactly were to post this but thought since we are talking blades; mower blades are not much different than knife blades.
Fred
Fred
