Sparky, the jig is best meant for doing the same knife over and over and over. The grinds will only be able to come partially up the blade, maybe half way, or the jig won't work right. At very best it is a finicky beast that has to be set up and shimmed meticulously for every blade style to have even a chance of working correctly. You will then have to adapt your designs and grinds to the capabilities of the jig instead of the other way around. Then there's the issue that it tends to be sloppy and likes to grab blades between the jig and grinder and either bring the whole thing to a halt or throw steel or belts all over.
I spent days with this POS trying to find the "magic" inside that was supposed to be there based on the claims. It was a total waste of money, IMO.
Edited to add: one other thing I just thought of. You have to unbolt the device and move it out of the way to change belts. This changes the setup and you have to realign.
