Perhaps the easiest to grind free hand but still need some experience . I can grind free hand but not as fast as i like .Fast moving belt and high pressure make it little tricky for me to hold steel steady and comfortable . . .I make one jig but it is very limited what can be grind with that .Then I watch this Japanese master ..........
I never seen someone to grind hollow like that ?? Never ! If you don't like to watch the whole clip start at 16 min. Ingenious ! And it can t be faster then that ................. no way !! 24 sec. for one side
So I make some small rest plate for my new grinder........I will finish tomorrow one smaller from steel , I need only to taper that hole . I didn't want to ruin this HT-ed 5160 blank so I used guide for grinding in it .I grind normal way ...from plunge to tip and it works .I will make some adjustable guide for that rest plate tomorrow to get rid of that clamp and i will cut other blank , HT it and i will try the Japanese way
Thanks Hiroshi Suzuki
Just watch what is fast grinding ....first tip , then little more and more and finished
