Sean Yaw
- Feb 26, 2019
When you are walking the top of the bevel towards the spine on a hollow grind, how do you ensure you don't grind a trough out of the middle of the blade? I.e., How do you make sure the thinnest part of the ground blade is at the edge, and not somewhere behind the edge? This is not an issue with flat grinding, but on a wheel, I am having a hard time seeing how to prevent this. Are there any references or videos you recommend for learning to hollow grind. Everything I have found on youtube just does it without discussing angles or blade placement on the wheel, or anything. Thank you.
