Hollow Handle Knife Shootout - Repost from BCUSA
This is a repost from BCUSA, so the guys names I mention in it might not make any sense to ya. Except for Iz, I'm pretty sure he's got his own forum here. With that said, let's get to it. To see info about the knife modified by field expedient check out this thread at BCUSA. http://bushcraftusa.com/forum/showthread.php/98188-cold-steel-true-flight-thower-mod-(hollow-handle-amp-sawback)
And no, I'm not a shill for, FE. He's just one of my buds and does neat work. He isn't a vendor or anything like that, just does it for the fun of it.
Upon receiving the hollow handle knife made/modified by fellow board member, field expedient, I decided to do a shootout between 3 knives.
The Randall 18, Boker Apparo and Field's knife.
Before testing I stropped all 3 knives to hair popping sharp. I also wrapped all the handles with tarred bankline, they are all just too small diameter without it, adds a little meat to wrap your hands around.
I've been using the 18 for a few years now so I know it's ins and outs, have also put the Apparo through some serious use, was happy to get my hands on a knife built by a friend and see how they all stack up with one another.
First lets check out the sheaths. Randall Made Knives are known for coming with some of the best leather sheaths you can get your hands on, pretty much flawless. Field's sheath is very high quality too, it's not perfect but you can see some damn good craftsmanship in it, not to mention made out of good leather. The Apparo sheath, it's a different story, it's very thin and flimsy. I would go as far as calling it dangerous, if you slipped a fell you might receive a knife through the leg. I have my suspicions that it's made from cat leather.
Next we will see how the joints on the knives are put together. Randall has pretty much perfected silver soldering, this 18 isn't the finest example of their craftsmen skills but it's still very nice. Field opted to have the blade welded to the guard, doesn't look great, but it won't break(keep in mind this is his first hollow handle, prototype of sorts, everything gets better with time). The Apparo I believe is screwed together(correct me if I'm wrong) and is very strong. None of these knives joints will give before the blades do, guaranteed. Note: I've talked endlessly with field, Iz and numerous other people about joining blades to hilts to hollow handles. My opinion is that silver soldering along with epoxy is the best route, I think others use epoxy and pins to hold it all together, which seems to work as well.
Alright, enough talk, lets get to the testing. This is a dense green tree that had fallen over from a storm and just so happens to be blocking the path to my favorite bushcrafting spot, so chopping was first on the list. The Apparo chopped the best, due to the heft of the blade I imagine. Next best was fields knife, it chopped well for it's weight. Last but not so least was the Randall, it chopped very well for its size and weight. Overall the Apparo dominated this test.
After chopping I moved to what I consider one of the most important tasks a knife can do, carving. Afterall, cutting and carving are what knives are designed to do. The Randall and Field's knife were the best carvers, the Randall slightly better but both very good. The Apparo is a big beefy knife, with a very thick grind. Even when I get the edge just as sharp as the other knives, it just doesn't carve as well. It can still do the tasks, just not as easily or effiecently. Thinner grinds are simply better for carving.
Here is a pic of another problem with thicker ground knives. Baton them into the wood for the initial cut on a notch and it can split the wood, thinner knives won't do this. When this happens you just gotta start over.
Cont...
Next we'll have a look at the sawteeth. Notice how the Apparo and Field's sawteeth are alternating, you can tell they are made for cutting wood. The Randall sawteeth on the other hand are not, they are made for aircraft skin.
This picture is showing how the sawteeth perform in a piece of green wood. About the size you'd typically saw for trap parts and whatnot. The Apparo saw starts cutting easily but doesn't cut very fast. Field's sawteeth are harder to get started but once you do, they cut very fast and effiecently. The Randall teeth don't really do much, I'm not gonna be sawing through a piece of wood with em. They can be used to aid in trap parts, making fuzz, etc.
Next up, everyone's favorite, batonning. I decided to do this test at home where I had nice, seasoned hardwood.
This pic shows each knife with it's piece of wood.
All 3 of the knives batonned great. I would give the edge to the Apparo or Field's knive due to the longer blade length. I thumped on all the knives pretty hard to baton this wood.
After all is said and done, I wouldn't feel under knifed with any of these. The two best knives were clearly the Randall and Field's knife. They both did fine at most tasks and excelled at carving. The Apparo is great to beat on, but will wear you out with any carving tasks, have your hands begging for mercy.
Thumbs up to field expedient for making such a nice toy and sending it to me to play with. I enjoyed it very much and hope you guys did too.
ETA: I wanted to add. I'd be fine with either the Randall or Field's knife on my hip during any outdoors adventure. Field does great work, not to pressure him too much, but I think he's got a future as a craftsman. Modding knives, making sheaths, etc
I also wanted to do something I've never done in one of my reviews before, show you my notes I take while testing the knives. They are kinda written in my own special language or klingon, I'm not sure which. :p If you need help deciphering just say so.
Great review machine :thumbup: Don't see to many hollow handle knife reviews good job :thumbup:
Thanks, Ivan.
I really enjoy doing reviews, and when one of your buddies "cobbles together a knife" as he says, how can I not compare it to others. Overall the knife did really well, I'm impressed with his leather work too.
Great review. I still dig hollow handle knives, I am a child of the Rambo era and not ashamed to admit it! I have owned many of them over the years from the cheapo bubble compass ones all the way up to my (at that time) grail Lile Sly 2. Wish I still had that knife...
Me too, bud. I remember my first hollow handle, got it when I was 20, traded a bubba'd mosin nagant for it. It was a complete set with pouches, original gear and all. The very tip has been chipped off but reground very nicely. I could kick my ass for selling it. Hold on a min and I'll link you to a pic of all my HH and sawback knives.
ETA: Forgot to say TY for the positive feedback. lol
ETA2: I hope this isn't frowned upon, afterall alot of people are members of both forums. I started a user group on BCUSA for hollow handle and survival knives. So if you dig those style knives you're in good company.
Here's the link: http://bushcraftusa.com/forum/group.php?groupid=129
I am also a fan of hallow handle knives, but mostly just for the cool factor, not for use. I'm glad to see a review where some are put to use and showing that they can be used and not break as easily as one would think. Great review!
Thanks bud. There are quite a few quality hollow handle knives out there. Don't really have to break the bank to get a good one. Apparo, Jungle King 2 and a few other good ones fall at 125 or less.
Like tknife above said, I'm a child of the Rambo era and not ashamed of it. :D
Nice review. The saw on Field's knife looks very aggressive. Being on thinner stock, I bet it tears through the wood pretty good, once you get it started. Good job.
Nice review m26.
I had one of the Buck 184s when they first came out & the teeth on those things didn't cut wood worth a damn either,but I believe they like the Randalls were geared towards AC skins.
TY. Yeah his sawteeth work pretty good, the ones he put on a cold steel bushman work even better.
Nice review m26.
Thanks bud. Long time no talk. I had a buck 184 almost a decade ago and I can't remember how the teeth on it worked, everyone says they sucked. If I'm not mistaken a pilot helped with the design of the 18, so it makes sense it's for aircraft. I need to find some aluminum sheeting and see how they cut that.
Cool post M26, I put a Boker Apparo through hell before passing it on to a friend after I picked up one of Newt Martin's original in a shorter blade length. Still wanting a Randall 18 pretty bad though. The CS mod seems to do very well.
TY. I remember your Apparo review, was excellent, pointed it out to alot of folks. I like that newer, smaller Martin knife they've made w/o the recurve, looks great. The CS mod did do well, I think it's only shortcoming would be edge retention due to the low hardness.
Cool review, great pics!
Thanks bud, glad you enjoyed it.
M26, Very nicely done. I'm a big fan of hollow handles myself, especially with the saw back. I'm a member of your group also. I'm think my next knife maybe one of those Bokers.
Nice review ! I think Mist Walker done a review on here with a hollow handle knife made by Schrade.....I have one of the Schrade Hollow Handle Survival Knives SCHF9...it's put up for one of my boys when they get a little older !
Thank you. What's your name on BCUSA, bud? The boker is a neat knife, very high quality, especially for a "far east" product.
Thanks bud. Mist does some good reviews. I'm gonna have to check out those schrades sometime. Just ordered a Randall so no new knife purchases for a lil while, lol.
