- Dec 9, 2003
I have a home electrical question for any electrically savvy people here.
So my 4 bulb fluorescent light fixture (only had 3 bulbs) inside my kitchen went out. I went to the hardware store looking for ballast and the guy suggested testing the wires first, so I went back home, pulled out my multimeter, and read 120 volts at the black and white wires coming out of the ceiling. So I went back and purchased the ballast and the light works again.
So here is the potential problem. I had turned the circuit breakers off while disconnecting the wires for safety. Well when it came time to put on the ballast I was thinking to myself what if I just turned the switch off instead of the breakers? That way I wouldn't have to spend time walking back and forth. So to see if it was safe I left the breakers on and the light switch off. I then tested the wires again with my multimeter. I was surprised to see a reading of about 40 volts. When the breaker is off then the wires read 0.
So I am wondering why, if the switch is off, is there any voltage going through the lines? Furthermore if something was broken and allowing voltage to go through the lines why is it only letting 40 volts instead of 120 volts? And lastly does this mean that I am wasting electricity, is there juice flowing through the lines and being used by the light fixture even when the light switch is off which I am having to pay for?
I was thinking I could at least try to change the switch but I am not sure if the problem is that simple.
Oh to clarify I live in a concrete condo for the last 2 years, and hadn't done anything construction wise involving that light or wires other than install track lighting in a nearby room.
I have a multimeter from batteryjunction similar to this one. It has lots of settings that I don't fully understand but I am pretty sure I got the setting on AC voltage. I don't know which place the decimal was in but I figure I should still be able to understand the reading. I left it on the same setting both times i tested the wires.
http://www.batteryjunction.com/a-dt-9205a.html
A preemptive thank you for all that provide advice.
