Home made disc sander ??
I have an old washer that the motor is still good on and I have been thinking about bolting some kind of flange on the shaft and then screwing a pressed wood or solid center round plywood onto it.
I know I would need something to mount the motor on and that without some kind of hinge system that it would only be good for square grinding.
I think I can make it work.Oughta be pretty cheap to build too.
Anyone already done this so I won't have to reinvent the
wheel?
Any suggestions or ideas that might help?
>>>>---¥vsa---->®
If you mix milk of magnesia with vodka and orange juice do you get a phillips screwdriver?
Khukuri FAQ
Yvsa,
I posted a topic the other day (Flat grinding tip of the day). I built my disk grinder out or an old belt disk combination. I use the disk only. The aluminum disk is covered with a 3/8" thick rubber disk. I clean up all of my flat ground blades (all i do is flat grinds) on this machine. It works wonders.
BTW, the motor already had a base that it was attached to.
Barry
http://albums.photopoint.com/j/AlbumIndex?u=126319&a=926274
[This message has been edited by BARRY JONES (edited 09 November 1999).]
Yvsa,
I made one about 10 years ago. It was my first knifemaking machine. I made up an aluminum flange that fit the shaft of the motor. You can buy flanges from Sheffields Knifemakers Supply. They charge about $15 for them. 1-800-874-7007 is there number.
I attached a piece of 1/2" Mahogany, just under 9" diameter to the face plate with wood screws and epoxy. This gives a more solid feel than grinding on the aluminum. I went with 9" diameter so I could cut standard size abrasive sheets to fit it. You also have to be able to reverse the rotation to grind both sides of your blade! I made lots of smaller flat ground blades on that grinder. I still have it mounted to my bench and use it now for sanding my Kydex material. It's a handy machine that I will never get rid of!
Neil
Just updated 10/31!! New Knives, New Pics!!!
http://www.geocities.com/Eureka/Meeting/5520/index.html
I made my disc ginder out of a 3/4 hp. dual shaft motor, disc on each end no need to reverse and the paper lasts longer. I built a copy of the table that truegrit uses on their disc grinder.
YVSA, I have a 9" aluminium disc I took off my 6 by 48. I have no use for it, and you're more than welcome to it. Just pay the shipping. Let me know if you want it. Take care! Michael
"Always think of your fellow knife makers as partners in the search for the perfect blade, not as people trying to compete with you and your work!"
