Home made Heat treating oven
Hello everyone.
So I'm looking to make an oven that's 6 inches tall 9 inches wide 50 inches long. Out of k23 fire brick reanforced by steel outside and mortard the bricks together.
This is what I'm planning on using for
temp control
https://www.mcmaster.com/#catalog/123/641/=1aineyb
With a solid state relay https://www.mcmaster.com/#6323t71/=1ainfu7
And probe
ttps://www.mcmaster.com/#3859k36/=1ainp4c
And
14 gauge kenthal a1 wire
Either that or get my stuff from
http://www.theceramicshop.com/store/search.asp
But if like to run it off a 120 volt system I cam go to 220 240 so anyways what would be the best way to go about it
Thought oppionions. Things I missed. Yes I know I need a plug. But as I don't gave 3 grand for the one i want. I figure it don't need to be large inside just big enough for a blade to fit in and long enough to fit any blade I may want. I'm also thinking of a dual system. 2 smaller ones but I can combine them for larger projects such as swords and things. I'm into hema so im it might be fun to make my own federschwert.
Long swords, and so on
And since these blade are large and ment to be smashed against each other allot the heat treatment must be very good if not perfect to avoid breaking and having a sudden sharp object go swinging or lunging at an opponent. We where protective gear but still very bad when it does happen. They've banned hanwie federschwert because of this but anyways I appricate any help I can get and hope to make this work out
