Hello all,
So I had a ball cutting down a backyard full of banana trees and now I need to sharpen my BK7. I inherited a lansky sharpener but it won't work for long fixed blades, not enough reach and the stones are too short. I really like the lansky system (have not tried the spyderco) so I canabalized it and made this:
The sharpening rods are made with 2"x6" DMT Dia-sharp Diamond Sharpening Stones (fine and extra fine) epoxy glued to a wooden door knob which is drilled out and bolted to a threaded rod. If everything works out I'll make more rods with thinner stones for smaller blades.
I have a couple of questions for the more experienced. Please see the paragraph below the third picture. Feel free to criticize or make any suggestions.
So far works great for me, a complete beginner. I have a few questions though?
In the picture below is how I set the angle. I use a protractor and the adjustable up/down dowel to set any angle. The vertex of the angle is measured at the blade edge. I placed the protractor flat along the width of the blade and in the picture below I read the angle as ~12 degrees (This is only an example). Is this a correct method for measuring the edge angle???
Below is how the angle is adjusted with wing nuts:
Thanks,
Sam
Thanks,
Sam
