talonturbo said:
Fist of all, I hope people don't think I'm trying to rip anyone off.
As long as you're not doing it to sell them you should be fine!
talonturbo said:
I've seen a few pics in the past of dremeled waves into Spydies. Don't get me wrong, I'll probably buy a factory waved Endura soon, but would like to wave my Native 3 and Matriarch as well (I mostly use tip down but might as well have my tip ups waved).
I'm not sure how well a Native 3 would work, as it doesn't have the hole inside a hump. Might be worth trying the cable tie trick first with that one?
talonturbo said:
My question is this: for those of you who have done this, could you please post a pic and some comments on how well it works or strength concerns?
I did this with a dremel-clone and a 1" fibreglass cutting wheel. Cut for a few seconds, then dip in cold water so as not to destroy the temper. I cut at 12 o'clock and 3 o'clock wrt the hole, then took the angle back from the spine to give it more room to catch. Tidied it all up as much as I could. Cosmetically, it looks horrendous, but it is all smooth (sanding wheel) so it won't cut up your clothes too badly.
It works VERY well most of the time, but it does depend on the pocket shape and material in my experience. Jeans are much better than say suit trousers. I have noticed no problems strength-wise. Despite its disgusting looks, it's probably my favourite knife. I suppose that's because I made it mine though
One point that has been brought up is the stresses upon the mechanism that such forceful opening could cause. I have experienced no loss of security in lock-up or any noticeable change in the way it feels to open, etc. without using the wave feature. YMMV
With a hook this big unless you are thinking about it it will always catch the pocket, but not necessarily open it fully. There is a certain technique to doing it every time. There is also the 'how do I get it out my pocket without it waving?' issue. I find (viewing from the top), twisting clockwise before removal from the pocket will draw as if it isn't waved. Twisting the other way even in loose pockets makes it catch much better.
Considering this was the first time I had used a dremel I think it came out well. My only advice is take is slowly and keep it cool. Maybe a cable tie to hold it closed when dremelling isn't such a bad idea either
talonturbo said:
I've seen a waved Native with a small cutout ahead of the hole, there's the factory Endura with the large cutout in front of the hole, and I've seen a Matriarch where the hole became the wave.
I'm just trying to decide if I should cut ahead of the hole or into it and the (wave) performance vs strength trade-offs.
I will post this on both forums as I'm not sure where the pics we're seen.
Thanks.
Both will work, it just depends on whether you want it to wave every time, or only occasionally when needed. Also, the smaller cutout can be made bigger but not vice versa
Show us when you're done!
It works very well as a bottle opener too...
