- Aug 12, 2002
OK, I picked up some Minwax wood hardener yesterday, but need something to pull a vacuum in, then put it under a bit of pressure to help get hardener absorbed in as much as possible.
I'm still stuck with hand tools for most of this. I have a Pump N Seal http://www.pump-n-seal.com/ which I know does a good job of drawing a vacuum in a mason jar. The only thing I have that is close to being able to push some pressure though is either the little 12V compressor in my truck(but I park in front of apt, and do most of my work in back) or a bike foot pump. Either way, I needed some way of making a container where I could draw a vacuum and put under pressure, and with some element of safety.
As I said, I know a mason jar works well with the vacuum pump. But a mason jar isn't rated for pressure, and even if it was, had no way of hooking it up to the bike pump(or compressor).
SO on way home from work today, I picked up some of those regular pop in valve stems, in the smaller .453" size. I'll take a mason jar lid, drill a hole(29/64" drill bit shoudl do it) and pop in the stem. THis should allow me to put pressure in a mason jar(Though it may require bit of extra gasketing.
THat let me draw vacuum or pressure, but wasn't safe. So I thought about what else I had around here. I got some christmas cookies from my mom in a little tin,a bout 4" wide and 6" high, that a mason jar drops in perfectly. Obviously, this isn't enough though if the jar shatters under pressure. SO I picked up a gallon can from the floor. It's 1.5-2" wider than the cookie tin. So I put an inch or so of sand in bottom of gallon can, put tin in middle,t hen poured sand around tin(again free, have approximately 120# of sand in two 5 gallon buckets in back of my pickup for weight). Mason jar jsut barely fits in inner tin, and then have 3/4"-1" of sand and another can around that for protection if jar shatters.
Total cost on this was $2.44 for the valve stems, rest I had around.
You could jsut bury the jar directly in sand, most of way up, but makes it harder and longer process to remove it to pour out extra hardener, or to put back down into sand. THis way I can do it quickly and easily.
So anyways, should be testing this out tomorrow or sunday(depends on how long jars take to dry, as they're full of soapy water right now). All I do to change from vacuum to pump is switch mason lids.
