That's strange. There is no standard for what various grit ratings mean, but 80 and 120 are probably extra coarse and coarse. There ought to be belts that are medium, fine, and extra fine.I guess it is technically a sanding belt. I ordered 80 and 120 grit - that is all I could find for it.
I also thought those to be coarse grits, surely there are more options out there. So, the main reason I bought this is, I make letter openers as some busy work and I sharpen them, pretty sharp. I also have a Work Sharp (which is also a belt sander, just has very fine grits available). It takes a long time to get an edge on these blades with the Work Sharp so I am hoping this will get it there quick and then I can tune it up with something else.That's strange. There is no standard for what various grit ratings mean, but 80 and 120 are probably extra coarse and coarse. There ought to be belts that are medium, fine, and extra fine.
A 120 grit belt will probably give you a toothy edge, meaning it is sort of like having minuscule serrations. A toothy edge could be good or bad depending on your personal preferences. You should be able to get a very sharp edge but definitely not a polished edge.
The main concern with belt grinders is that they can overheat the edge, leading to poor edge retention. This is less of a concern with coarse belts than with fine belts. It is also less of a concern if you can run the grinder at a low speed.
I do not see enough information about the Hook-Eye machine to say much more. I use a different kind of small belt grinder designed for knives, a Work Sharp Ken Onion. I especially like it for machetes and very small blades. It comes with a wide variety of belt grits, so it can be used for almost any knife. Whether the Hook-Eye is anything like the Ken Onion, I cannot say.
I figured it would be easy too, but that seems to be an odd size. I have a 3" x 24" belt sander for wood working - I figure if worse comes to worse I can take one of those belts and split it.I'm not familiar with that machine - but I did find a manual for one that called for 1 1/2"X24" sanding belts.
you should be able to source those from several different places in varying grits .
