I currently own 2 of the 3 you've listed, the Hossom Dionaldo, and the Derespina Mod 8.
The ergos, fit & finish, and durability are about the same on both karambits.Both are from top notch makers, but I must admit, the Derespina feels better balanced in the hand.
The Hossom model is rare and discontinued, and also worth a small mint, so if you get your paws on one I wouldn't recommend using it. My 2 are safe queens only. If you plan to use or carry the knife, I'd get the Derespina. Rich's CS is top notch, and if you have an issue he's always willing to help.
I can't speak for the Strider PS, but I do have the HS. Well made knife, built like a tank, and sharp as a razor.
You should try to handle which ever knife you choose before you buy, because the curvature of the blade differs greatly from Strider to Hossom to Derespina, and that may cause you a bit of a problem.
Good luck, I hope that helped.
