If you're worried about finishing large flats on a big blade, it could go either way. Hot rolled should be flat enough that you can smooth it out and finish it without too much work,unless you've got really hard scale like Mike brought up (I've run into it a time or two also). I've never had any problems with it varying too wildly in thickness or anything though to where it would be hard to work with for a fixed blade.
Precision ground can also be a toss up though because it will depend on what grit they ground it with. I've had some bars that had what appeared to be about 80- 120 grit tracks running the length of the bar. Those can be a real pain to grind out, especially when you consider that the bar was already ground down to the finished dimension you wanted and now you're taking it thinner. Other peices have been ground to a much higher finish and cleaning up the flats was no trouble at all.
