How (and Whether) to Heat-Treat Tomahawk Heads
I gather that I’m not alone in wondering about the best low-tech way to heat-treat tomahawk heads, so I’m posting this question in a couple of forums where someone who might have some ideas might read it.
I’ve got some very inexpensive tomahawk heads whose blades seem to have been made by lap-welding a steel cutting bit in between layers of softer iron or steel. I have no real way of telling just what kind of steel is involved. I’m interested in your thoughts on the following:
1. How do I tell whether I have to heat-treat each head at all? Thus far, I’ve checked out only one of the tomahawks. Specifically, I tried scratching the cutting edge with a file, and then scratching the area of the eye with a file, and the two scratches seem to be almost the same in depth. I suspect, then, that the cutting bit on that hatchet is roughly as soft as the eye, which it should not be. Any ideas how, with low-tech equipment, I can tell whether the edge is hard enough? (Part of this question is, how hard is hard enough for general tough wilderness use? And what sign do I look for to see, with low-tech equipment, whether a given blade is of that hardness?)
2. Assuming that one or more of the hatchet-heads has a bit that’s too soft, what’s the easiest low-tech, foolproof way to fix the situation? I’m assuming that what I want is a differential temper, with a somewhat-hard (but not brittle-hard) cutting edge, and a softer eye/poll area. How do I do this? One thing I’m thinking of doing is using some variation of what Alexander Weygers mentions—he wrote of seeing a Filipino smith heat-treat a bolo blade in one step, by heating the entire blade to cherry-red, then simply chopping it a fraction of an inch into a section of cut squash or gourd, the shape of which roughly corresponded to the curve of the blade. The effect was to cool the very edge rapidly, while allowing the rest of the blade to cool more slowly. It seems to me that a similar effect might be achieved by similar means using some kind of live vegetable material (squash, or whatever), or by dipping the very edge of a hatchet-blade into thick mud, etc., etc.
2(a): Would this work well to heat-treat a tomahawk head?
2(b): Right now, the bits of these tomahawks are VERY dull, and it will take a good deal of stock removal to bring them anywhere near cutting sharpness. It’d be easier to do the sharpening before the heat-treating, but if necessary I guess it could be done afterwards. If I sharpen them before the heat-treating, does that increase the odds that I’ll crack the edges during the heat-treat? Advice on how to proceed?
3. How, if at all, would your advice change if the tomahawk head were made out of a single kind of temperable steel?
Vegetable quench ? That's a new one for me !!! ...You could heat it up , quench edge in oil ,then take out and let heat from the poll area temper the edge. A 'hawk of all the same material could be HTed the same . You could even heat just the edge and quench in oil and temper.Hard to tell exactly what you will get with mystery steel but you want an adge not too hard as it's for impact .
You also do not want to have to sharpen them any more then needed. The edge geometry on axe/hawks will allow chopping and if the steel is mid to high carbon it will hold up without re-sharpening.
I have been making quite a few for hunters in my area. They are using them in place of larger knives and hatchets. They only have to pack a small folder and a hawk.
Have you spark tested the edge steel yet?
I haven't spark-tested them yet--really, I don't know how to tell by sight how high-carbon a steel is from a spark.
B. Finnigan, when you say "you also do not want to have to sharpen them any more than needed," do you mean I should sharpen them BEFORE heat-treating? (I'd rather do that, as the metal will be softer and more easily shaped then.) Or do I have to wait until AFTER heat-treating? (to avoid cracking the bit, if thin bits crack during heat treatment; I think I've read that that happens with knives sometimes, but have no idea about hatchets.)
Do you know who made these tomahawks or where they came from?
They came to me via Crazy Crow Trading Post, and are stamped "India". They do indeed appear to be hand-forged, from the hammer marks, and I can see the "sandwich" construction by looking at the inside of the eye. They actually look better than some that I've seen. Yeah, I know--they're not H&B Forge or Ft. Turner--but the cost ($10.30 apiece) was such that I could afford to get a few, experiment, toss them around without worrying too much if I lost or broke one, etc., etc.
You only want to sharpen after HT'ing them. If they are not a good mid to high carbon steel then they will not hold an edge especially if you are chopping with them. If the steel is low or no carbon then you will not get a good edge and the one you have will have to be re-sharpened.
If the grinding sparks look like fireworks with smaller sparks comming off then there is some carbon. I am sure someone on the forums has a good picture of carbon sparks and the approximate C percentage.
