Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
What angle would u say? 82ish/90ish like a countersink?Not to take any of Tracys business but you can take a piece of 01/w1 drill rod and make your own..Just gring the point to shape and heat treat it..
I use the flaring dies from USA Knifemaker and a 1/2 ton arbor press. The flared tube gives you another mechanical connection that is stronger than the often used straight tube. Use 1/4" thin walled tube and countersink your hole to .4" diameter for a slightly below flush flare (below).
do you leave the tube long and then file or sand it to meet the scales?
I second that. If you make your own, It's best to be turned and polished on a lathe, it would be tough to hand grind it. If the angle is off it could cause splits.Tube length = handle thickness. Make sure you square the tubing before you flare it. Also, unless you can "grind" a near perfect cone, don't try the methods suggessted above.
Jeff
ps 82 degree six flute contersink is the ticket for this simple operation
really nice outcome... I'm swithching to this as well. i've been doing it the old fashioned way and compared to this, mine looks like crap.
