How are these knives
I was thinking about buying these 2 knives, I would like to get any thoughts you might have about them.
Camillus Black Heat Tanto Assited Open Knife C2375
Boker - Escrima Folding Dagger (EFD) Knife - 2200
I have the Camillus Heat but in plain clip-point, and I love it! It was an excellent deal at $40 and is worth twice that. Very nice fit and finish. Blade lock-up is tite with no blade play. Assisted opening is very strong, actually a little too strong unless you hold it fairly tighly. It opens quickly, although it takes a good bit of pressure on the finger flip to start the blade movement because the spring is so strong. There are a few sharp ridges on the handle near the top where the flip is, but could probably be filed down a bit. The steel is very thick and takes/holds an edge very well. I have dropped it several times on pavement and the handle has yet to show signs of damage. It feels very nice in the hand and the large thumb-studs and finger flip make it easy to open with gloves. I have tried the spine whack test with no lock failures. I like mine so much, that I am going to get the Blaze as a smaller model to use around sheeple. While not as perfect as my Benchmade Mini-Ambush, it is still an excellent knife for edc. I stongly recomend this knife, you won't be dissappointed, unless the tanto version is alot worse than mine.
