To post a picture, you either use html code, which is somewhat complicate, or you use UBB codes. To just post pictures, UBB is simple.
The problem is that I can't tell you how to insert a UBB code because if I type one in my message, the software will interpret it instead of displaying it. So, bear with me on this and I will tell you how to make your picture come up.
UBB codes are always enclosed in square brackets: [ and ]. In order to fool the system into letting me show you the codes, I'm going to replace the square brackets with "curly braces": { and }. When you go to actually make your post, just remember to use square brackets instead of curly braces.
First, your image must already be posted on some website somewhere. Because of space limitations, bladeforums.com will not host your picture for you. If you don't have web space somewhere, try photopoint.com.
To insert a picture, start making your post as usual. Then, open a second browser window and navigate to the image you want to include. Place your cursor on that image and right-click on that image. From the pop-up menu, select "Copy Image Location". This will place the image's URL into your copy/paste buffer.
Return to the first browser window where you are forulating your post and add a line beginning with
{img}
Remember, I'm using curly braces to fool the system. You'll use square brackets so that the system will recognize the code.
Then, right-click and select "Paste" from the pop-up menu. This will paste the image's URL into your posting.
Finally, end the line with {/img}.
So, the complete line might look like this (notice that, to further fool the bladeforum software, I've omitted one of the t's in the http part of the URL):
{img}htp://www.balisongcollector.com/bm42/42straightS.JPG{/img}
Now, if I was to put this line in adding back that missing t and replacing those curly braces with square brackets, here's what would happen
Good luck with it. I know you can get it to work.
Chuck
Balisongs -- because it don't mean a thing if it ain't got that swing!
http://www.balisongcollector.com
