- Dec 6, 2011
How close do most of you try to get when cutting out a knife pattern using an angle grinder with a cutting wheel? I just tried using my angle iron with a cutting wheel on an old saw blade just for fun. With the shower of sparks and such it was hard to follow the line too closely. Do you typically get close and then use a bench grinder or something to get closer to the final shape?
I think I may try my wet saw next time and see how that goes. Does anyone know what type of blade works best in a wet saw for cutting steel?
After that I'll probably try the band saw. I am guessing that the band saw may be the overall easiest, but I wanted to try some of these other ways first.
What about using a plasma cutter? Does the heat get too high and potentially screw up the knife steel?
