- Mar 6, 2022
I found an old axe head metal detecting. The face is split right down the middle. Could the hardenee bit have rusted away?
Will a little bit of glue wrapped with duct tape fix?Inserted steel bit using the fold-over forge welded method that had a cold weld that popped apart.
That one pic taken inside a car looks a bit like a fossilized prehistoric skull !I found an old axe head metal detecting. The face is split right down the middle. Could the hardenee bit have rusted away?![]()
Ive seen that with an old keen kutter! Im guessing this one is basically scrap now.In full seriousness in old wrapped-method axes that delaminated, a lot of folks would drill holes and put some rivets through to keep it shut. Granted, the bit portion seems to be completely missing here.
Ahhh it may be, haha. I thought it was a cavemans clothespinThat one pic taken inside a car looks a bit like a fossilized prehistoric skull !
Axeisaurus Rustus , perhaps ?![]()
Or you could get it cleaned up with electrolysis and have a smith forge-weld in a new bit!Ive seen that with an old keen kutter! Im guessing this one is basically scrap now.
Make a frankenstien axe!Or you could get it cleaned up with electrolysis and have a smith forge-weld in a new bit!![]()
One of the benefits of this construction was that a smith could delaminate the bit and weld in a knew carbon blade once the old one was worn out. If you did that, you’d be keeping with a historical tradition that isn’t commonly practiced any more. I’d refurbish it just for the sake of saying I have it!Make a frankenstien axe!
That would be super cool. Looks like it was a Kentucky patternOr you could get it cleaned up with electrolysis and have a smith forge-weld in a new bit!![]()
Would a smith know how to properly set a new bit inside nowdays?One of the benefits of this construction was that a smith could delaminate the bit and weld in a knew carbon blade once the old one was worn out. If you did that, you’d be keeping with a historical tradition that isn’t commonly practiced any more. I’d refurbish it just for the sake of saying I have it!
Yes- they’re out there. I’ve met a few that do that kind of work. I’ve also seen a smith on these forums who produced a wrapped head axe, and I’m sure he could do that… though I can’t remember who that was.Would a smith know how to properly set a new bit inside nowdays?
It would be neat. Ive cleaned up most of the outside and havent found any makers marks. And am looking around.I think it would be extremely cool to have a blacksmith repair this axe if financially practical.
I'm not sure what that sort of thing might cost, but I figure you could probably save money doing as much of the prep work yourself as possible.
