- Mar 19, 1999
I'm not 100% sure what the choil is, whether it's where the grind starts or if it's the notch cut where the grind starts.  I call it the, "It's time to get a new knife notch", because if a knife had been sharpened so many times that the edge is at the top of the notch, the blade probably needs to be reground or replaced.  At any rate, how do other makers cut the notch on the edge side of a blade between the edge and the tang?  The notches I like are the rounded cut.  All I've come up with is to use a 1/8" thick cutting wheel but the notch will be squared.  I grind hardened steel and would prefer to cut the notch after I've ground a blade.  I tried a search for "choil" but the results found "quench oil".  Thanks for any input.
Bill
"There's nothing friendlier than a wet dog"
"The more people I meet the more I like my dogs"
Bill
