I finally decided to take attack the blade on my CS Recon 1 Tanto Folder, specifically to get rid of that shiny black finish. Took the knife apart and removed the "Teflon" coating. That stuff flew off with a bit of sanding. I then used 400 grit wet/dry paper to remove the scratches. I now have a blade that's pretty good looking but much too shiny.
What I would like to do before I reassemble the whole thing is to dull down the finish. Ideally, I'd like to end up with something that looks like the finish I've seen on some of the better tactical blades. OK, I don't expect to get anything that good. I will be real happy with a nice non-glare finish.
Is there a way of doing this by hand, maybe with some sort of abrasive compound? My only power tool options are a Dremel Tool and a small electric drill. Any suggestions most appreciated!
By the way, while this knife might have a hefty feel and look to be solid, taking it apart showed up the places they really cut corners. Still a good buy, but I guess in the end you do get what you pay for!
