Use metal polish, stropping compound, or some other very fine abrasive material. Apply to a soft cloth (ideally microfiber) and rub for a long time, occasionally stopping to swap out the cloth/abrasives as necessary. I've only done it once, it took over an hour for a small blade. Not worth it to me to try again. There may be better ways out there.
Well, maybe 'almost all'. Depending on which stainless(?) you're referring to, some methods may work better than others. Stainless like 440A polishes very easily, but something like D2 ('almost' stainless, anyway) or S30V will take much more work, with the right abrasives and compounds.
Doing it by hand with unpowered tools could be very slow (maybe taking forever), if just using metal polish or compound. By hand, the most-often recommended method is using wet/dry sandpaper in a tight progression of grits. Most factory 'satin' finishes might emulate something in the 320-800 grit range; starting with sandpaper at a similar grit, and working up through a tight sequence of higher grits, through at least 2000 or higher, then polishing with compound or pastes, will likely do the better job. If the 'stainless' is a very high-wear steel (especially with high vanadium carbide content) like S30V, finishing the finer grits with diamond abrasives will work much, much better, down to at least 3µ compound or finer.
I'll flatsand to 3000, it'll pass as a "near polish". The extra time spent polishing beyond that is not worth it to me, "been there/done that".
As is mentioned above tho it's important to take the sanding as far as you can before starting polishing-- the diff between polishing a 1000-grit surface for instance compared to even a 2500-grit surface is HUGE.
