- Nov 24, 1999
I'm going to order a lockback kit from Koval and I want to modify it alot. Its for a traditional lockback with brass liners, engraved bolsters, and wooden scales. I want to knock the bolsters off because I don't like the pattern and make full length G10 scales instead.I also want to add a thumbstud and a pocket clip.It doesn't look like there is room to put the pins for the pocket clip all the way though the handle without interfereing with the spring.Would it be strong enough if I only put the pins though the scale and liner on 1 side? Any ideas on attaching the pocket clip would be appreciated. I haven't ordered anything yet so if you think I should forget the pocket clip and just get a sheath let me know that too.Thanks alot.
Fix it right the first time, use Baling Wire !
