Boltaron - A recycled ABS/acrylic PVS extruded alloy sheet material used for making sheaths. It has excellent impact strength and abrasion, chemical, and fire resistance properties.
If it's the factory Spyderco Hossom series sheath then it is Boltaron not Kydex. My understanding is that they are both thermoplastics, but I not sure it will reshape like Kydex does. Just wanted to throw that out there.
More to the point, they're both thermoforming plastics, and the Boltaron sheath can be tightened just like Kydex (as I described in my post above).
You could also try a candle for spot heating
You may get multiple tries if you under heat it but if you overheat, you run the risk of melting it.
