- Nov 6, 2012
i have been sharpening on my norton stone (320 grit) and can feel a wire burr on the edge i have tried using steels to remove it and stropping to remove it but that just pushes it to one side how do i remove it?
White back, I read about Roman Landes's experiment where the embedded thermal sensor read over 2000 celcius.I see so many people sharpening dry, that video included, what you are doing when you sharpen without oil or water is overheating the first couple of microns of your edge ( you know. The part actually doing the work) and taking the hardness right out of it. You will not feel it because you have the thermal mass if the rest of the blade between that and your finger, but Roman Landes has measured it. Always use oil or water as a coolant while sharpening. If you are dry sharpening an otherwise properly heat treated blade just using coolant might be enough to fix the edge softness that is giving you that problem
-Page
Yes, I would buy an English translation of Roman's book too. Sadly not big enough market for it.I have personally discussed Roman's research and findings from this experiment with him at Ashokan the evening he presented it there, his research in that area was sharpening on fine stones. The annealing effect was only a couple of microns deep, beyond that the thermal mass of the blade absorbed the energy. As a former metallurgical associate engineer who used to spend hours looking at metal phases and thermal effects under microscopes, what he described made sense, and I did some experiments dry sharpening and wet sharpening identical blades made of 1084 when I got home, and found that the dry sharpened blade developed a wire edge (deformation burr) where the wet sharpened edge felt harder on the diamond stones, and did not develop a burr, and was starting to shave hairs off my arm at the end of the blue DMT stone step, while the dry sharpened one developed a nasty wire edge that would grab and cut aggressively for a short time on the red stone, then after doing the burr removal thing would cut as a toothy edge at cardboard and paper etc, but not as cleanly and for nowhere near as long as the wet sharpened edge. You can do what you choose, and if your choice is to sharpen dry, so be it. Personally my money is on Roman's research. Once his book is available in English I will be buying a copy.
-Page
