How do I sharpen a chisel grind edge on a Spyderco 204
Hello fellow members,
I'm trying to sharpening my co-worker BM 975 with a 30 degree angle; however, I could not get the edge as sharp as I like. What is the proper way to sharpen a chisel grind knife with a Spyderco 204?
Any suggestions would be greatly appreciated,
Sharpen like regular, but only do the angled side. After about 10 - 15 strokes on the angled side, take 1 light stroke on the flat side to remove the burr. Should be A LOT easier.
-AR
- AKTI Member ID# A000322
Jackyl, should I keep it at the same angle as I would with a normal double grind edge or should I angle in more towards 30 degree?
Sorry it took so long to get back...use the 30 degree angle.
-AR
Never changed a grind, but I do notice that there is a light sharpening mark on the flat side of chisel grind. Always suspected this was the way it was done.
Brandon
"You should never never doubt what nobody is sure about..."
I would recomend that you lay the stones flat in the base and sharpen the chisel grind as if you were using the a benchstone. IMO this is the best way to but a good edge on a chisel grind, it's the way I but the edges on all the chisels and plane blades in my shop . Hope this helps.
after you make about 10 passes on the beveld
side strop it on the back of a "legal pad"
works great , also a cotton buffer pad and some jewelers rouge that you can get at most hardware stores to fit a grinder works
best if used before it gets too dull. this is all so the best way to sharpen serrated
blades also . this how i do all my knives
"if ignorant both of your enemy and yourself
you are certain to be in peril"
I don't think you will do much more than thin the bevel some on the thirty degree. It may take a long long time. Do the magic marker thing (wipe down the egde on the magic marker) to see the effect. Thirty is probably too much, thats only a 15 degree on a chisel ground knife. If all you are doing is thinning the bevel go to the forty dgree. A fifteen degree angle is a little thin IMO..
Roger Blake
Damn!!! That's right, use the 40. DOAH!!!
-AR
[This message has been edited by Jackyl (edited 02-24-2000).]
It's amazing how accurate the bench-stone and thumb technique can be. Feel the edge to the correct angle (100% edge contact on the stone), wedge with your thumb(s) between blade and stone, and push away. I had one chisel grind and I was able to improve the factory edge considerably using only this freehand technique. When doing the 'back' side, the blade should be flat, but 1 or 2 degrees saves all the ugly scratches...
Humbly,
RLR
[This message has been edited by RLR (edited 02-25-2000).]
