- Jan 22, 2005
I bought a new 1 1/4 pound camp axe and it was rather dull....far from sharp like my sebenza. My question is should an axe be razor sharp? and do you sharpen it at the same angle as you would a knife? Thanks guys
You are right of course. But if you continue to go to ever finer stones and polish up the edge you can have an incredible edge -- until the first chop. Then the last hour and 45 minutes of the two hour project were wasted.jmxcpter said:Traditional sharpening of an axe is done with a bastard mill file, preferably a 10" or 12" single cut version. If you want to go nuts, use a coarse stone after the file work. There's not much to be gained by trying to get a polished edge on an axe. Working up to 600 grit max should give you a good cutting tool.
fracmeister said:You are right of course. But if you continue to go to ever finer stones and polish up the edge you can have an incredible edge -- until the first chop. Then the last hour and 45 minutes of the two hour project were wasted.
My real advice is to keep it sharp and keep it handy. Much easier to maintain an axe than reprofile it.... unless you have a tormek.
