I thought I heard that BM was using Bodycote to do their coating on the newer blades. If not, they should. The boron carbide coating they developed won't scratch or wear off. It is harder, 93-95 rockwell, than most materials it comes in contact with. They will coat a blade for you as an individual also. Here is a post where Darrel Lewis provided the stats on their coating.
BORON CARBIDE
I may be able to address a couple of things that have been said in previous post.
The Black coatings on all of Microtech's knives that have been made during the past eight months are coated with BORON CARBIDE.
Diamond Black TM. Boron Carbide are extremely hard thin ceramic flims
with a nano-crystalline structure applied in a vacuum chamber via
physical vapor deposition.
HARDNESS 93-95 ROCKWELL C
CHEMICAL RESISTANCE As a ceramic material Diamond Black films are inherently inert. Specific formulations of Boron Carbide can be made to be highly resistant to gases,harsh chemicals and salts.
APPLICATION TEMPERATURE Boron Carbide is deposited at less then 250F
This temperature is lower then the tempering range of all steels used in the knife industries.
ADHESION As strong as the base material itself. no flaking or chipping should occur with normal use.
MOLECULAR WEIGHT 55gm/mole
DENSITY 2.52GM/CC
MELTING POINT 2282F
COLOR DARK GREY TO BLACK
DERMAL TOXICITY Safe for prolonged contact with skin.
I hope this will answer some of the questions you may have about Microtech's Boron Carbide coatings.Since I am the one doing them, if you should have further questions please Email
me.Dlewis@bodycote-na.com
Darrell Lewis
YOU MAKE IT FIRST-WE MAKE IT LAST
