How do they do it? Those angled plunge cuts.
I have seen more and more of those plunge cuts lately that are not perpindicular to the blade edge, but at 30-40 degrees in the ricasso area as opposed to straight up & down if you know what I mean. I have always taken great care to have nice pretty plunge cuts, although during my learning curve I had my share of screw ups. Those other folks doing those plunge cuts have me wanting to give it a try.....how do you fine folks pull it off?
Have a great weekend, and thanks in advance.
Hank
I use the edge of the 9" disc to get a sweeping cut, anything else angled I try to use a file guide.
I ride the belt off the platen about a 1/4". It will sweep in a radius from the edge to the spine at about that angle and leave a more rounded transition a the top of the plunge.
One like this.
Rather than holding the blade horizontal when grinding the bevels, you hold the blade at an angle.
Thanks,
Del
Thanks,
Del
Yeah, just that easy, ain't it, Del?;) :D
I've tried a bunch of times to do this and make it look right, but have yet to succeed. I know it's only a question of practice, but this seems to be the most daunting skill to develop (at least, for me!).
Yep Delbert...thats what I am talking about....will take suggestions and give it a try....Thanx!
I also use a fileguide but I cut my plunge in initially on both sides with a file and then clean up on the grinder, leaving the guide on until after 220 grit. The file is slow but precise.
Matt
I do all of mine freehand and the angled plunge is something I just started doing this year. I have in mind a dagger that would look really cool with angled plunges. (ok maybe thats going a bit far)
Thanks,
Del
