- Mar 14, 2000
I'm just wondering... Get's me into trouble sometimes.
I spent a lot of time making my first forged blade. Thanks to a lot of you here on the forum I had a real good recipe for my first blade and it turned out great considering I knew nothing firsthand prior to starting. Excellent quality steel (5160) from a John Deere tractor. All forging done below critical. Total of 9 normalizing cycles during and post forging. Triple everything heat treat. Tempered at 330 degrees in my oven first time around and dropped the temp 5 to 10 degrees with each subsiquent treatment. Poor man's cryo treatment (dry ice and kerosene) for about 30 hrs. or so between the second and third tempering cycles. Etched the blade to reveal the temper line. When I finally got her finished the edge flexed beautifully over a brass rod and she holds an edge despite a lot of 1/2" manila rope being cut. After my third sharpening she chopped through a vintage (1943) 2 X 8 made 55 cuts through 1/2" rope and still shaved hair. I'm pretty proud to say the least. The one test that is missing is the 90 degree flex. I'm saving that for the next 10 or 15 blades. All will be tested to total destruction until I am confident that each successive knife's performance is repeatable and reliable. After all is said and done I will know without a doubt just exactly what my knives will be able to withstand before failure.
How do all of you assure your customers of the quality of your work? Is there a way for the customer to know what kind of quality is behind our blades, or do they just have to take our word on it? If I remember correctly, I believe that Jerry Shipman had his doubts prior to maxing his "Bill Burke" knife. I'm sure his doubts have been permanently put aside after his ordeal. There has to be a better way than what Jerry went through.
Rick
Rick
