Mixing Wood Dye Powders With Alcohol
To speed up the mixing process, mix powder wood dyes into 1 tbsp of water first, then add isopropyl alcohol. Let the wood dyes rest 30-40 minutes after mixing. Dye powders should rest a little longer when using an isopropyl or rubbing alcohol base. Mix until the wood dyes are completely dissolved. For the most color potency, it’s still best to mix only the amount you’ll be using in the near future, but the wood dyes will store longer as an alcohol base dye stain.
Mixing Alcohol Dye Liquid With Solvents
Just like with our wood dye powders, a small amount of our liquid wood dye goes a long way as well. These are the top-of-the-line alcohol base wood dye liquids. A good starting ratio is 1/4th tsp. to 3/4th tsp. of our liquid dye to 6 oz. to 8 oz. of lacquer thinner, denatured alcohol, acetone, or other non-oil based reagent (start with 1/4th tsp and work up, these are very color potent alcohol dyes). Our liquid alcohol dyes do mix with water, but really are designed more for non-oil solvent bases. We recommend storing and mixing the alcohol dye solutions in a rust-resistant container such as glass, with an air tight lid to prevent contamination or evaporation, and storing alcohol dye solution at a warm room temperature away from intense light, sparks, or flames.
Once mixed, the liquid stain should be covered when not in use. Add the alcohol based wood dye liquid gradually to the solvent reagent while stirring, or use a jar with a sealed lid to shake well. You can even combine all 5 wood dye colors together to create the color combination of your dreams. It’s best to immediately mix only the amount you plan to use. Our wood dye liquid will last for some time once it’s mixed with the reagent, but it’s always best to mix fresh dye stain for color potency, or add a few drops of alcohol dye concentrate to freshen the dye stain up if desired. Please note: Keda liquid alcohol dyes are designed to mix with solvents as a traditional wood finish option. The liquid dye may be used with water base, or water based sealers as well, but for a direct wood stain dye, the liquid dyes perform at their best as an alcohol base wood dye. When mixing Keda alcohol liquid dye into water, a little stronger ratio may be required.
If you have any further questions, please feel free to
contact us. Our experts will do their best to assist you through any wood dye mixing questions you may have. As with any wood finish product, please wear the proper gear such as gloves, goggles, and perhaps old clothing. The dyes will stain several types of fiber materials.
