the first edge on all the knives i make is put on there with the belt grinder, this will be an even easier task when i finish making the new grinder, with a 1.5hp variable speed motor.
when i need to resharpen one of my knives i use a coarse DMT diamond stone, i sharpen one side, keeping the angle correct, until it forms an even burr. then i sharpen the other side until it formes i burr. i keep repeating these steps until all the chips, if any, are taken out. i then go up to fine diamond and use that the same way as i do the coarse, until all the coarse scratches are taken out. then i use an 800grt japanese water stone, 1,000 grt water stone, then a 6000 grt. water stone. make ure you fallow all the directions you recieve, when you buy the stone, on prepairing the stones for use.
you can bring the edge up to razor sharp with a strop and red rouge like chris hatin does to get the final polish on the edge.
make sure you keep a consistant angle on the edge, or it will never be wicked sharp.
