Bruce and all,
I took a class with Don Fogg and Chuck (can't think of his last name) at JC Campbell on making a katana. The steel was 1065 I think. What Don and Chuck had rigged was a forge with sand in the bottom with a temp sensor in the sand that controlled the gas. The cycling didn't work very well because it was a blown forge and , although the gas was shut off the blower continued cooling the forge too quick.
The hardening was done in water that was slightly heated. I assume that the violent cooling was desired because the curve was needed.
I did the cooling, about 3 seconds in the water, then out for 3 to 4 seconds then back in the water for 10 seconds or so.
Chuck took my blade to the anvil before it completely cooled and did some straightening with a hammer.
That method seemed to work well for Don and Chuck but I don't have their experience or expertise. I'm building another forge to use some of his methods. I have a length of 3" pipe that I will cut a slot in the top and fill with sand. That pipe will be suspended in the forge, horizontal not vertical like my present forge, and heated with a couple of naturally aspirated burners. Because I like 5160 also I will use oil to quench.
Does that sound like a workable plan? I welcome opinions, especially criticisms, because it's still in the planning stage.
Lynn
