How do you keep handles from cracking?
I was working on a knife for a friend and when I went to drill a 5/16" hole in the oak handle, it chipped the wood. I have to re make the entire handle now, because the chip is so large. :mad:
I wanted to know how you guys keep wood handles from chipping when you drill it.
Also, do you drill both slabs at the same time using the blade as a template, or do you do one at a time??
Thanks for the help!
~Brian
I do one scale at a time, clamp or superglue it in place and drill. I use a plywood base to drill into to support the bit when it comes through. Go slow when you can feel the bit begin to come out the other side.
Masking tape will work wonders to keep the wood from chipping. Just place a piece of tape on your scales, mark where you want your hole and drill. also, like Dave said, make sure you have a good support to drill on.
Make sure your drill is sharp & straight also... (also a drill press would be useful for precision -i saw your other thread ;) )
All good advice above; also, spur point or bullet pilot point
bits will help a lot to prevent cracking out the hole.
Regards,
Greg
I use a backup/waste piece of stock on the bottom/back side of the piece I am drilling so when the bit comes thru it's still cutting something else and won't chip. I also use bullet point bits, or work up thru several sized HSS bits, use sharp bits and plunge gentily at the end.
Oak is pretty "chippy". You should use sharp tools on it. And back up the hole when you drill. You might try a different kind of wood.
