blgoode said:
Damn Mike. I need practice getting mine to look integral
I have found that I will need to use my wire drill bits to get the holes just big enough then ream them a little bigger. I had too much slop in the initial holes so I used a little spray glue to hold them in place. I have read where this will form a seal as well. Looks pretty good but I will try to acheave the integral look in my future efforts.
Look at what Kit wrote, again!
Use straight flute "taper pin reamers" after you drill your pin holes. You can get them at MSC, or other industrial/machine shop supply places.
Here's what I use;
1/8" = 2/0 taper pin reamer
3/32" = 4/0 ditto
1/16" = 6/0 ditto
Put some dykem down the holes so that when you ream them, you can see the depth of cut, and don't go all the way to the bottom. If you do go all the way, you will have trouble keeping the bolsters straight on both sides when you set the pins, as you wont be able to keep the bottom of all the holes the same size. They must be the pin size that you drilled for at the very bottom.
Just clean your pins, and bolsters, and set them like you normally would, making sure to give them enough muscle to fill the reamed holes, and you should be in business.
The bolsters will not come off after that, and hopefully you should get great results.
When you are setting the pins, and if you have done the rough cut bolsters correctly and left a bit of overhang at top, and bottom of the tang, smack the areas that overhangs(top, and bottom) a few times. That will make sure that it's right up against both sides of the tang when you finish grind.
There's no need to put substances in any of that to seal. All you will end up doing is contributing to a poor fit.
BTW, taper pin reamers mentioned above are the size of small drill bits, and not very expensive at all. I've had the same set for years.
Good luck!
