pendentive said:
The only way to get more sharp is to sharpen on progressively finer and finer abrasives.
Sharper does not equal more polished
You can have an edge with a coarse finish which is sharper than an edge with a high finish.
I have seen edges off of 100 grit AO belts which could shave hair above the skin.
Sharpness is a matter of edge alignment, uniformity, and lack of defects (dents, chips, rust, etc.) .
... sometimes ultra sharp is ridiculous. You'd end up spending more time maintaining it than actually using it..
I think you need better steels, in general if you are looking to maintain very high levels of sharpness move out of stainless and into tool steels with very fine grains and high levels of hardness.
Plus of course your ultra-sharp knife will eventually just degrade to a regular shaving sharp knife, it doesn't jump from ultra-sharp to dull. So it stays sharp longer, not shorter as it has that extra lead.
Of course if it is *very* difficult for you to get ultra-sharp then you have to balance this against the gains, of course a lot of such problems are due to the way in which the blade is ground, unsuitability of the steel to the type of blade, etc. .
Sharpness is also only one factor in cutting ability, for some knives it isn't one of the critical elements (wood cutters), however on some blades (flimsy material) it can be quite critical.
-Cliff
