For edge retention, in preliminary testing, 1095 from GEC, the best I have tested for edge retention so far, retained an edge better than AUS8, but not quite as well as 440C. I haven't finished testing, but that is my result so far.
My results are tainted in that I am unable to test the hardness of the 1095. GEC anneals the tangs of their blades. For a Rockwell test you need a flat piece with parallel sides. Since the GECs I have are flat ground, the tang is the only place with the proper geometry for a measurement. The 440C was 58HRC. The AUS8 was 59HRC.
Since I use a manila rope slicing test, which does put a premium on abrasion resistance, it is not to be wondered at that the 440C did better.
To put that result in perspective, 440C performs a step below VG10 and 154CM in edge retention when all ar hardened to approximately the same hardness.
