It is found almost exclusively in ferritic steels, however, that a sharp drop in Izo-d value occurs at temperatures around 0°C (see Figs. 1 and 2).
I believe a good refernce for you is the API-650 code on steel tanks....A36 carbon steel is permitted for use in tank shells to -4F and lower without any concern for brittle failure
The first cousin of A36 is ASTM A53/A106 Grade B (piping material). Use is permitted to -20F according to ASME B31.1/B31.3, however this is a "fully killed" steel and properties are slightly better than A36.
What does the AISC manual say about this....
[Stainless] Steels with ferritic or martensitic structures show a sudden change from ductile (safe) to brittle (unsafe) fracture over a small temperature difference. Even the best of these steels show this behaviour [sic] at temperatures higher than -100 deg C and in many cases only just below zero.
In contrast austenitic steels only show a gradual fall in the impact toughness value and are still well above 100 J at -196 deg C. See Selection of stainless steels for cryogenic applications.
I've used thin machetes very hard in sub-zero temps with no problems whatsoever. I wouldn't worry too much.
Actually, machetes work well because they are usually considerably softer than std knives so they have a measure of toughness to them at the loss of edge holding, so what you said makes perfect sense.
