- Feb 24, 2001
I've read so much about them, but never heard how they are performed. My mental image is of taking an open knife and slamming the SPINE of the blade against something like a table or workbench, to see if it overwhelms the lock's ability to keep the blade open.
Is this what people do? If so, how does one hold the knife so that IF the lock fails, the fingers are not injured? Do you hold the handle in the manner in which some close an Axis-lock (i.e. thumb on one scale, tips of fingers on the other, nothing in the path of the blade)? That seems like a pretty insecure way to hold a knife that's being whacked against something.
This test seems questionable to me. When performing any test on a specimen that will then be used in its normal capacity afterward, one has to wonder if the test itself may have caused a fault that will not be discovered until the item is placed under stress again, and fails.
That is why I question the utility of a spine whack test on an individual's knife. On a prototype or test knife at a factory, yes, you could measure stresses and see what it took to make a design fail, and then you can assume that additional specimens manufactured to the same design standards would hold up similarly. That's different from testing your own carry knife. If you get it to fail at a certain point, do you throw it out? Do you still carry it, with the assumption that the test stresses were well above those the knife will face under normal use? How do you know that the fact that you pushed the knife to failure does not mean the next time it will be weaker, and fail sooner??
---Jeffrey
---Jeffrey
