Stainless steel works by being coated with a layer of chromium oxide that prevents further corrosion. If the steel is in an environment where that layer can't form (like in the mud under a swamp) then the stainless isn't and it corrodes. Patina functions similarly by providing a surface layer that prevents further oxidation of the underlying steel. The process is most famous for occurring on copper alloys but it happens on steel as well.
"If you want a super patina, boil some acetic acid, coat your blade with it, then wash with water to neutralize the reaction. It will turn the steel near black, but it won't rust. "
Interesting!
Why boil?
Many chemical reactions occur quicker at hotter temperatures. Don't ask me why, I'm not a chemist, just something I picked up years back in high school![]()
To completely dork out on the chemistry, heat equals energy, and some reactions require a certain level of energy before they occur at a reasonable rate. I could blither on about activation energies, entrophy, enthalapy, and Gibb's free energy, but if those terms mean anything to you then I'd be wasting even more of our time. Succinctly, divalent iron (+2) creates less problematic oxides and trivalent iron (+3) creates more problematic oxides. Divalent iron is patina, trivalent iron is rust. If you create a coating of divalent iron oxides then the trivalent iron oxides are less likely to form.Many chemical reactions occur quicker at hotter temperatures. Don't ask me why, I'm not a chemist, just something I picked up years back in high school![]()
