Bobby Craig
BANNED
- Jul 19, 2010
11111
They don't compare. One is a coating, another is blade finish.How does satin finish compare to TiNi/TiN?
I always thought they are two different coatings.Titanium Nitride or Titanium Aluminum Nitride (also known as DLC) is an extremely hard and tough coating that serves to protect a blade against scratches and corrosion. If you see a scuff on a DLC blade, it is usually where the coating has ground off whatever contacted it. From strictly a hardness point of view, DLC is actually harder than diamond.
Where one needs protection from corrosion, a TiNi coating has some advantages if one tends to ignore proper maintenance. I have some Bucks and Kershaws with DLC coating and they look great, but I have not found any performance advantage over a properly maintained satin finish blade.
Yes, DLC and TiNi are different coatings. They both look to serve the same purpose, protection against scratches and corossion.
