I would describe cross filing as holding the file handle in your dominate hand pushing the file away from you into the material at a closer to 90 degrees to the work piece and draw file with the handle end of the file in the opposite hand away from you and pulling or drawing the file to you at a greater or lesser than 90. I work mostly from the choil to the point but keep in mind the file cuts less at both ends of the stroke and heavier to the center. I added a couple of pictures of the piece Im working on now and its all drawn I just really am not comfortable cross filing or it simply doesn't give me the same feeling of control and find it much harder to control my lines. Long full draws to define a line and shorter draws to work smaller areas along the line.
One tip.. don't file over debris I keep a brush in my hand and constantly dust off the debris and hit the file constantly with your file card. Don't wait until you create a very very ugly gouge that takes all the fun out of filing and a chip stuck in the teeth of your file will make a mess. INSTANTLY and UNFORGIVINGLY The thought makes my toenails uncurl!
I start and finish with the same file and I mark my file so the same side is always down and I a draw line on the up side of the file and keep my work under that line and avoid changing file length as the coarseness of the file is different from one length to the next . It makes it very hard to maintain symmetry from side to side. I like a 10' flat bastard for a 4" length and a filing area of about 1/2".
I dont want to imply Ive done a lot of knives. This is only my second kn ife but I use a file a lot in my gunsmithing making parts mostly cross filing and preping or removing pits from barrels that I am going to blue and its all draw filing. On a round barrel you create many minute flats all the way around the barrel running the length of the barrel staying at it untill the pits are gone then Emory across the grain then polish and blue. Those Ive done many of.
The only power tools I have used is the drill press for my handle and a belt sander and a scroll saw for the scales so it takes a lot longer but I love the feeling of the milling effect the file creates. As you can see the profile is very simple and there is not a lot of material to remove after the initial line or profile is finished. That takes a while.
This one is semi-finished (polished for heat treat 600 grit) on one side and Im about to hit the second side with the Emory and get it ready to HT. I still have to knock the edge off with a stone before it goes in the fire as its pretty sharp as is.
I keep my templates nearby and refresh my lines regularly (as needed). Also I use a piece of blackboard chalk and rub the file in the area I am using it seems to help to release the chips but does not mean it replaces the brush and card by any means. That part is ultra critical. Remember if you score one side and have to remove additional material the same amount of material must come off the other side or the blade will not be symmetrical.
Just sneak up on your lines and a sharpie will help you see where your at and patience is the name of the game (wish I had more). There comes a moment when you'll feel the need to step back and its time to lay down the file. Its not going any where.
