Cliff Stamp
BANNED
- Oct 5, 1998
I was repeating the work I had done with the 1095 paring knife with a larger blade in O1, which also had a similar hollow grind. I had used it extensively already just as EDC and set out recently to run it through a full standard of uses to benchmark it fairly quantitatively. I sharpened it just as with the paring knife, flat to the stone, starting from 220 SiC all the way up to a fine chinese waterstone which is finer than a 4000 grit synthetic japanese waterstone.
I used it in the kitchen on vegetables, meats, breads, etc., no problem, cut very well as expected. I then tried it out on fabrics, paper, cardboard, plastics, again no problem. I then took out a piece of hickory flooring and carved up a piece, about 200 slices, to my surprise the edge had folded over. Damage was barely visible, but I could feel it burred to one side. Now the 1095 knife easily did this with no damage, and in fact cut much harder woods outside.
It was odd I thought that O1 at 63.5 HRC was so much weaker than 1095 at 66 HRC, then I suddenly realized that even though both knives were sharpene by the same method since the O1 blade was much wider it was taking a more acute angle. So I do the math and determine the edge is sharpened at 2.3 degrees per side, the 1095 blade is at 4, so it is almost twice as obtuse.
So that is the lower limit, two degrees is fine for foods and most materials but you need more obtuse angles to carve hardwoods, how much more obtuse I'll find out over the next few days on some various types of wood.
-Cliff
-Cliff
